welcome to TL.
check ebay.co.uk or other ebay. they are plenty paper and cd manuals
I think we may get a reply in a month when he's tried all of those, :lolYou need to have a known starting point with new plugs anyway, even if that's not the only problem.
Then you need to do a better job of describing the symptoms exactly. The exact sequence or what you do & what occurs...in neutral? Sidestand position? Clutch lever squeezed? Run/kill switch set to run? Headlight bright? What does the odometer display say? Any codes in dealer mode? Key position...do you hear the fuel pump prime? Push start button...Does starter crank the engine? Any sputter like it's firing at all? Any smell of fuel? If you look down the throttle bodies do you see fuel being injected? If you dribble in a bit of fuel or spray some ether or starting fluid does it fire up & run for a second? If you test spark from the high voltage lead on an external new grounded-body spark plug in shade or dark room do you see spark at the plug? For both cyls? Do you know any history? When did it run last, was it stored & how long? What happened to it since it last ran? How old is battery, and is it fully charged? Did you try jumping it? What's the voltage on the switched power line while cranking? How old is the fuel? How old is the battery? Does the headlight dim a lot while cranking?
