Don't think the TL ECU is more sensitive than other especially. If it gets crap signals it will behave like crap. If you have doubts about any of the mods that have been put in then take them out. Clutch switch bypass is one that has been known to mess things up. Go through the usual standard stuff like plugs, oil, filters etc. The fuel filter is a good one to check. Do a tour pulling and reseating all the main electrical connectors to break any corrosion layers that may have built up. Give it another run and see how you get on.
Is this miss at 6000rpm in any gear?
Cheers
Cheers
