My starter relay went kaput, just got the new one in today.
I put it on and connect everything up. BIke turns on, fuel primes. then i push the starter and the fuel primes again.
Ihold down the starter and the fuel primes constantly i let off the priming stops.
im thoroughly confuesed right now and my bike is just sitting there all alone in the cold.
And im not getting any fault codes?
Have you tried Sawzall? :O
It would depend on why the relay was replaced and if there was a problem like this prior.
At a minimum the battery voltage would need to be checked/charged to eliminate it.
The main power take off to the wiring loom is at a junction inside the relay going on to the starter motor.If the battery is very low the starter will take all the current causing problems else where.
Another bump for the JarrkoSparko mod and the StevoTheDevo headlight out start mod...There is also the option of running a 30 amp fused link straight off the battery to the loom bypassing the relay.
