Evening,
Putting a lining inside a tank seems like asking for trouble. If the stuff is flaking off it could be lodged anywhere in the system all the way through to the injectors. I'd suggest pulling the whole thing apart and cleaning it out. There's a recent thread on all sorts of clever ways to clean tanks. These normally just involve a bit of mild acid but in your case I'm thinking some pea gravel or ball bearings chucked in to grind off the remnants of the coating wouldn't go amiss.
Do the tank and flush some injector cleaner through and see how you get on. You may have to dismantle the fuel pump as well. Pull it out and inspect it to see if any junk is lodged in there when you do the tank.
Probably going to need a fresh pair of Marigolds.
