I put the same question on TLP;
Hi,
I have a nagging question that I will be able to answer myself if someone who has access to the exhaust ports will kindly give me a precise measurement (in milimiters).
Thanks.
As above - The inside exhaust port edge diameter is 43 mm. Measured off a spare motor.
Thanks for the response.
Now if this is the available flow, then I'm afraid the rear spigot causes a restriction !
There is a ring of weld that's right at the opening that measures 40mm ! ( I hate ignored details like that ).
Now this could be easily removed if we had easy access, like not having to lower the engine....
Let me take a picture, I have a spare one on hand;
This should have been welded on the outside !
I hate taking the time and energy and money to put high performance headers knowing there's that shit !
I am with you on this one, I attacked mine with a die grinder to totally remove that weld a long time ago, and it hasn't cracked or fallen off. I haven't had the means to test the performance or possible temp drop in the rear cylinder, but it sure makes me feel good about.
Good for you.
Yeah I was wondering if I should leave a little welding on or not, regardless, if you grind to where it's equal to the pipe there should be enuf left.
I should have exhamined mine a long time ago, it was always a question mark but I did not think it was that kind of problem with it.
More like smaller diameter problem... not a stupid bad manufacturing decision !
I left it alone thinking there was nothing you can do anyway..
Now its a splinter on my mind !
