I have a parts collection very similar to yours Jimmy. :laugh
Keep at it. :banana
Keep at it. :banana
lets see some photos of the welded swing arm.... he turned up an hour later with it all welded beautifully. .......
From what I hear that salt is a nightmare - I guess there is not much you can do about it if you are a year-round rider:thumbup My bikes will never be pristine - they are ridden way to often, in all weather....but that's how it should be.Wow, nice job on the engine and frame, was the engine in good condition before you cleaned it, I just couldn't et mine anywhere near that nice, it was like my metal in the cases were discoloured (prob from the salt they put on the roads here in the winter :rant ) Looking forward to seeing it come together :eatcorn
At this stage the race/recess interface appears perfect - too small and I imagine it would split leaving more cracks to weld:no - too big and it will 'flog' out over time...lets see some photos of the welded swing arm.
Afraid the neighbours cats stay well away from our place because of this big boy:deviousBugger ! Go and kick the neighbors cat instead Jimmy .
The larger gauge wire will be fine. Just a little bit of excess weight.....
Can anyone tell me if I can use slightly larger diameter (about 1/3 bigger) wire than standard to extend various parts of the loom, for the purpose of hiding all the bits normally covered by the fairing. I have plenty of wire in all colours I've salvaged from broken appliences etc, and would rather use this than buy new stuff.
