I need 4 10mm high tensile bolts 1mm pitch (fine) * 70mm long, where do you think I could get some and know that the are man enough to hold on my new radial calipers :devious
I found this place
http://www.namrick.co.uk/browse.asp?PCID=9
It says tensile on the tin but I don't want to risk it.
I can't get a standard replacement as I am using 10mm spacers so the bolt needs to be longer.
Also do you use any threadlock when putting in caliper fastners?
I found this place
