A BIG HELLO! This is my first post as a new member and I have recently bought a black D&K imported TLS from Ebay in a crazy impulsive moment.
Its has an issue that i need some help from you guys that have had the bikes with the standard clutch springs fitted.
The clutch pull is very heavy and I can see from the service history it has EBC CSK 71 uprated springs.
I adjusted the cable pull as per your forum.
I have stripped the clutch and noticed straight away the outer plate has been fitted with the tabs in the wrong slot. Correcting this has not helped the heavy action.(Its the five spring early clutch.)
The cable is obviously stretched so today I bought a new genuine cable and decided to pick up a set of Barnett springs.
My question is ...for general riding would I have be better fitting original stock springs and gaining a lighter clutch action?
EBC quote 10% stiffer and Barnett quote 25 % stiffer. OR Should i stick with the EBC springs, since my complaint is heavy action and not slippage?
Perhaps I should just fit the new cable and Barnett springs and try it. But if the pull is still heavy is that something youve got to live with??:confused
Please focus my mind for me and sorry if the info is already in the forums.
