I am about to do the (+) mod based on JarkkoT's diagram here:
http://www.tlzone.net/forums/frequent-tl-mods/30292-grounding-mod.html
In JarkkoT's wiring diagram, the following connections are indicated on the relay:
85 = old coil +12V
86 = ground
I just purchased a 12V 30A relay DF005 "Baja Tough" 5-pin. The pin diagram on the back of the package indicates the following:
85 = ground
86 = to switching means (I guess in the TLR's case, the coils)
Seeing as the 85 & 86 pins are reversed depending who I listen to (JarkkoT or the relay manufacturer)... what to do?
Does it matter?
Please advise...
It doesn't matter which way you connect it unless it has a diode across the input.On a normal relay pins 85 & 86 are the connections to an electromagnet that closes the points,so it doesn't matter which way they polarised.
Cool... thanks for confirming my suspicions.
I just have the 1 link to the (+) mod instructions (given above).
Are there any other threads that have more information, pictures, or helpful advice to make it go smoothly?
EXCELLENT Smithers!!!!!!
Thank you very much.
:pirate
:pirate
:pirate
You're lucky you have no questions about that drawing Glenn or I'd fly over there to :bitchslap you :laugh
No probs reading that wiring diagram, mate!
I read "squiggle." hehehe
But anytime you want to fly over here (not to :bitchslap me) for :cheers ... you're mighty welcome to!
Added to the list :thumbup :laugh
Hell i'm sure Glenn or myself will even provide a place to stay!!! But you gotta buy your own beer.....:laugh
:cheers Eh!
Discussion Starter #11
:cheers Eh!
Hehehe... NOW you got it, eh !!!
I think we should make you an honourary Canadian... you have 1/2 the vocabulary down pat already!
:laugh
