Posh git :laughpaul.haydock said:Ended up fitting a camera/monitor instead:devious
Mark, these look identical to the ones on the trike, except with the CF finish.Toledo said:Just curious about what anybody thinks of these on e-gay? item number 130033105896 are they worth it :O apparently, they don't "blink" very brightly but don't look too bad.....................
Not tried it properly yet (bad weather) but early resullts seem good See threadstlsgreen said:Posh git :laugh
seriously any good?
paul.haydock said:Not tried it properly yet (bad weather) but early resullts seem good See threads
http://www.tlzone.net/forums/showthread.php?t=77584
http://www.tlzone.net/forums/showthread.php?t=77846
I had a pair of carbon mini indicators fitted to the back of the bike between the pipe outlets:coocoo They started to melt over a period of time:banghead so i replaced them with intergrated LED tail/indicator lights(£50 new off ebaylooks great). I used the bulb and holder out of the mini indicators. A small screw holds the lens in the mirror, take this out and insert a small allen key in to pull off the lens. The lens is a tight fit and small bits broke off mine but wasn't noticable. Due to the unit being LEDS (only 2 inside:coocoo ) there is no reflector fitted so i used a piece of tin foil. When replacing the lens i would put a bit of grease on the edge it assist it in as it is a tight fit.Toledo said:Mark, can't remember if I did use 'em:confused just like the look of them.
Paul, how difficult was it to change over to halogen bulbs :O where did you get hold of the bulb holders?
Couldn't use it with LEDs as the light off them is forward directional and so has nothing to reflect, unlike standard bulbs.tlsgreen said:Could you not use tin foil with the LED's and see how that improves things? Just an idea?
The differance is like night and day. I had flush mounted indicators on before and was vary hard to see from the front. But i still left them on anyway.Toledo said:There's a thought :O did it really improve them Paul, and did you keep std blinky-blinkers on as well as ones in mirrors :O
Cost me £30 but just found theseToledo said:they look like the same as on "The Trike" except mark/jen have got smoked lens on with std bulbs................had a look at 'em today and for me not bright enough. So you can get these mirrors with amber lens too? then do the tin-foil mod'?
