I purchased my TL only a couple months ago, but realized with a little research on here that it had an exhaust leak. I decide to tackle this while installing Rifleman's 1/5 instert & clear clutch cover and Vandriver's tail risers, since I would need to adjust the pipes anyway. I have tried several repositionings and still the same leak where the midpipe meets the collector on the right side:banghead It has gotten better, but it is still bad enough that you can feel it if you put your hand by it. What can I do to solve this? Is there something I can put in there? :O I'd rather not try to bend the pipe and then end up worse than I am.
