I noticed real recently that my bike has a loud tick that sounds like it is coming from the front cylinder...I know TL's tick I've owned mine since 97' But I dont see any exhaust soot around the exhaust joint...I get the feeling its an exhaust leak. but where? Its higher piched than normal and almost metallic sounding. I seemed to notice it more with the M4 exhaust now on the bike...Is the header thinner maybe than the factory Pipe? letting more noise escape?
I wonder about the joint under the motor as well cuz it seemed kinda loose slip fit....Should I put some of my aluminum silicone in there? We make a Silicone that will definately hold up but I dont know if I need it.
My bike only backfires down low just a few real light poofs nothing flame shooting or nothing.
My new motor has about 2 thousand miles on it. It couldn't be the valves could it? I am running 10/40 Suzuki Oil as factory says. The bike is running great just has a much louder than normal sounding tick.
Oh I did not replace the exhaust gasket at the head when I switched exhaust do you think it could be compressed and be the culprit? Like I said no visible soot around the head...
I just changed the oil like two weekends ago also. Any suggestions are welcome...
