gday folks,
just wondering if the outer engine covers and ancilaries can swap over between the tls and the sv?
also will a vandriver clutch cover and 6 bolt pressure plate fit the sv motor?
any other differences that would cause headaches?
im planning on fitting a 06 sv bottom end and box under some 97 TLS heads, cams, throttle bodies. and ecu. is it doable?
cheers.joe.
The clutch is completely different, too. The TLR pressure plate won't fit.
Use search. The engines are obviously quite different.
Out of interest, if you were to swap the whole Sv clutch side covers with the inner and outer covers from a TL, might that not work or are the bolt holes completely different :O
SV cases have different mounting points too, so you can't bolt the SV cases into a TL or visa versa.
I don't know if you can swap the whole side cover though.
i believe the complete clutch side...cover swaps...it also has a much bigger breather set up on the sv.:)...
