1 - 3 of 3 Posts
Never heard of them, but here's the catalog w/ TL cams too:
http://www.tuningmag.net/dcentral.p...der=katalogy&file=katalog_#kent_cams_2005.pdf
PART No. APPLICATION CAM LIFT VALVE LIFT DURATION VALVE TIMING LOBE CENTRE ANGLE VALVE CLEARANCE CAM SPROCKET KITS
INLET/EXHAUST INLET/EXHAUST INLET/EXHAUST FIGURES INLET/EXHAUST INLET/EXHAUST
SUZ19 TL1000R STREET .433” .383’’ .425” .375” 257o 250o 19/58 55/15 110o 110o .008’’ .008’’ -
11.00mm 9.75mm 10.80mm 9.55mm 0.20mm 0.20mm
SUZ20 TL1000S STREET .408” .383’’ .400” .375” 256o 250o 18/58 55/15 110o 110o .008’’ .008’’ -
10.36mm 9.75mm 10.16mm 9.55mm 0.20mm 0.20mm
SUZ21 TL1000R / TL1000S RACE .433” .401’’ .425” .393” 257o 258o 21/56 56/21 108o 108o .008’’ .008’’ -
I also see that Falicon offers (or used to offer) an adjustable cam gear set for an astronomical price, and Schnitz has a set in stock for only $450.
http://secure.cartsvr.net/catalogs/catalog.asp?prodid=368196&showprevnext=1
Kent Cams are well known over here, and pretty good. Used to run a set in my Wiseco 1170 Katana :)
1 - 3 of 3 Posts
