1 - 3 of 3 Posts
i read this on the net! has anyone heard or done this?
TL1000R
The TLR has a soft and hard rev limiter. This simple mod will remove the soft rev limiter on the TLR and give you an extra 500rpm.
Remove the seat to get to the ECU then remove the larger of the two conenctors. You will see some white tabs in the side of the connector push it side ways and this unlocks the wires. Pull out the #25, black/brown and voila, soft rev limit removed.
this is the link i read it from
www.carlsalter.com/TL1000R.html
Yes, it's true. But pointless.
as patracy said it is true. there is a timing retard eliminator that you can buy, instead of cutting the wires, and just plug it in and your done. I put one in my tiller and did get the extra 500RPM; and low rpm smoothness which I did not expect. the hard rev limiter, if I am not mistaken, is only removable by reprograming or changing you computer. a freind of mine has done this with the motec system but that is way out of my price range.
1 - 3 of 3 Posts
