1 - 20 of 24 Posts
Is the a list on the forum somewhere that shows which parts are interchangeable between the TL's and other Suzuki's and other makes?
I'm sure I've seen it somewhere but can't find it now I need it :banghead
I'm trying to find out which other models have the same rear disc (rotor) as my 97 TLS and ideals :confused
RonAyers.com
Part# is 69211-33E10
Year Make Model Group Part Desc.
1997 Suzuki TL1000S REAR WHEEL DISC,REAR BRAKE View
1998 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
1998 Suzuki TL1000S REAR WHEEL DISC,REAR BRAKE View
1999 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
1999 Suzuki TL1000S REAR WHEEL DISC,REAR BRAKE View
2000 Suzuki GSX-R750 REAR WHEEL DISC, REAR BRAKE View
2000 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
2000 Suzuki TL1000S REAR WHEEL DISC,REAR BRAKE View
2001 Suzuki GSX-R750 REAR WHEEL DISC,REAR BRAKE View
2001 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
2001 Suzuki GSX-R600 REAR WHEEL DISC,REAR BRAKE View
2001 Suzuki TL1000S REAR WHEEL DISC,REAR BRAKE View
2002 Suzuki GSX-R750 REAR WHEEL DISC,REAR BRAKE View
2002 Suzuki GSX-R600 REAR WHEEL DISC,REAR BRAKE View
2002 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
2003 Suzuki GSX-R600Z REAR WHEEL DISC,REAR BRAKE View
2003 Suzuki TL1000R REAR WHEEL DISC,REAR BRAKE View
2003 Suzuki GSX-R600 REAR WHEEL DISC,REAR BRAKE View
2003 Suzuki GSX-R750 REAR WHEEL DISC,REAR BRAKE View
Handy!
For other parts, just find the bike's make, year and part # you're interested in. Copy the part # and plug it back into the "Where does this part fit?" search window on the Ron Ayers home page. Looks like that's what Gigas did!
:confused :dowhat
RonAyers.com
Part# is 21200-02820
1998 Suzuki TL1000R CLUTCH UNIT COMPLETE View
1999 Suzuki TL1000R CLUTCH UNIT COMPLETE View
1999 Suzuki TL1000S CLUTCH UNIT COMPLETE View
2000 Suzuki TL1000R CLUTCH UNIT COMPLETE View
2000 Suzuki TL1000S CLUTCH UNIT COMPLETE View
2001 Suzuki TL1000R CLUTCH UNIT COMPLETE View
2001 Suzuki TL1000S CLUTCH UNIT COMPLETE View
2002 Suzuki TL1000R CLUTCH UNIT COMPLETE View
2003 Suzuki TL1000R CLUTCH UNIT COMPLETE View
2008 Suzuki GSXR1000 CLUTCH UNIT COMPLETE View
Looks like the 2008 GSXR slipper clutch is a direct bolt in.
:confused :dowhat
RonAyers.com
That is VERY interesting :eatcorn
The 650 has right way up forks not USD forks :confused, so no
what other top and bottom yokes fit the TLS ? I iamgine the GSXR ones do but would like it confirmed if thats possible ?
Only TLS yokes fit the TLS and only TLR yokes fit the TLR, everything else requires machining to fit either model.
The GSXR yokes use the same headstock bearings and can be made to fit but the ignitional switch position and lockstops are wrong
that sounds like a headache trying to make them fit, did it take much "adjustment" to get your GSXR yokes to fit and work as they should ?
I don't have the ignition barrel and made my own lock stops as it's a race bike, so yes, piece of cake :laugh
Stu (Ring-in) has fit them on his S, he made new lock stops but not sure how he got around the ignition barrel.
GSXR TL Rear Brake Hose
Hi There,
I was wondering would the rear brake hose from a GSXR 99 - 00 fit a 98 TLR.
Would grately appreciate your help.
Cheers
69480-02FA0 is the TLR part number and not the same as any other bikes, so you may find the GSXR hose is the correct length but the cushion rubbers/hose ends may be different
Sam, is it only the ignition switch position thats different between the S and R top yokes :O i.e. I want to move the ignition switch position to the right on my S, therefore will an R yoke do the job, accepting that the steering lock will no longer work as intended :confused :)
Yes, they can be swapped if you don't care about the ignition lock. I'm not sure if the clip-ons have the same M6 locating bolt position though
:thumbup time to look for a yoke then :)
Sam, please, me & clip-ons :confused - when is that ever likely to be a consideration :lol
Yeah, only fools try and wrestle a TL with toothpicks :laugh
Also, for the rear brakes, you can also upgrade a bit (if you don't mind some weigfht) by putting on the larger Hayabusa disc and matching larger caliper hanger.
1 - 20 of 24 Posts
