1 - 20 of 35 Posts
No s**t. I talked to and drove and rode in a car called the Kawasawki ZX9R CAR. (Google it) And he is gonna help me do one with my TL 1000 motor with the VEE-TWO cams and the forged J& E pistons Check out this site to see what I mean. ( I had a serious accident in 2003 and can't risk the ride after 12 operations and an MRSA infection) (I would lose both legs. so I get to keep TL 1000 S and make it corner at about 1.7 G's
Wayne
Links
http://thekneeslider.com/archives/2007/04/26/kawasaki-zx9r-open-wheel-street-racer/
http://www.youtube.com/watch?v=ywgf8btIn68
might even try the turbo thing
Wayne
Kooldaddy
Nashville
Interesting video, Good luck with your project
that exposed flywheel which i assume is an attempt at reverse is an engineering disaster. :no the use of the zx front light is very cool :thumbup
interesting stuff
The TL engine is not well suited to sideways G forces, oil starvation is a big problem. Quite a few people tried them in grass track cars and were forever blowing them up, in the end they nearly all went down the RSV Dry Sump route.....
Just something to know and be aware of :thumbup
i'd drive it ! :thumbup
What about a 'busa motor? I understand you already have the tlr motor but if it has oiling problems it won't last long.
don't use the V2 cams for this project they won't have the right charactersitics (too peaky) but good luck otherwise. look forward to seeing the outcome.
Well about the v2 cams.....
I am adding a belt driven centrifical supercharger with a liquid to air intercooler and secondary shower injectors with water injection and shave the tops of the J&E forged pistons. It oughta sound pretty kool. I got some yosh ti multicolor cands that are on the original bike. I will photo everything and keep you postede as work progresses, looks like a spring start date (2001).
Wayne
ok so I dry sump the motor not the first one I have done. A Cosworth/Hart bda and several race bikes. An oil tank and a couple of scavenge pumps and some early suzuki upskirt oil squirting. all possible. and I tig weld lots of alluminum stuff from time to time.
wayne
Discussion Starter #11
interesting stuff
The reverse gear has been working since 2006 and I drove it yesterday and it works fine thank you. It uses a high torque gear reduction starter off a race car. Oh and by the way honda has used this approach on al their aspencades and large bikes for about ohh... 15 years.
Wayne
Discussion Starter #14
Shrek,
Did you look at the car I was refering to? it has TWO seats and 4 wheels. dry sumping the engine shouldn't be that difficult, lotsa nascar stuff out there and I should only need a 3 stage pump into the de-aerator and then run AN fittings back into the main pump.
2.g lateral accel will be like sliding front and rear on a 2 wheeler.
gonna try it.
Thanks
Wayne
ya shrek! TWO seats and FOUR wheels! got it?! :laugh
If you're doing that just buy the flat top Wiseco pistons. They are advertised as 12:1 but are infact 11.43:1 when measured, unfortunately they can't be dished to drop the compression further and the short cam chains stop any significant spacers been used under the barrels :devious
Good luck :thumbup
Discussion Starter #18
Oh and on the oil starvation thingy, I will use the output shaft (sprocket shaft) to mount the u-joint and drive shaft. lateral acceleration would be fore and aft, this is a position the motor is quite used to. It's not gonna be a live axle chain type drive.
:cheers
1 - 20 of 35 Posts
