ISR, BREMBO many oem mastercylinders!
Thanks Troy. I am definitely looking at oem. But could you name a few please ?. Just want a used one off ebay.ISR, BREMBO many oem mastercylinders!
Thanks... I have been told by a mate in the Uk that a ZXR750 will do itThe TLR master is not a direct fit. It uses a reservoir that bolts directly to the master, with the mounting screw inside the reservoir. To fit the Rizoma (I presume you want matching reservoirs for brake and clutch), you will need a master with the plastic nipple + c-clip retainer fitted to the master.
I had one of these on one of my Tillers that the previous owner installed. Not sure what bike it was from, but it had a mount for a mirror, which tells me it was a standard or cruiser. It also had a different lever and clutch switch.
Dudz, to complete this install, you will need the master, lever specific to that model, and determine if the clutch switch is normally open/closed.
