Just as the title says, how do i get access to my sidelight bulb as i want to change it?
2000 TLR
Thanks in Advance
Daz aka Cadburys Man.
Front parking lamp? :dunno
Sidelights are genrally parking lights. The AU & US headlights don't have them just the Euro's I think. Having never seen one I can't help. :)
undoo the D shaped plastic fillet under the nose fairing and the side light is a twist fit rubber with a pushin bulb :)
Come on Gigas, you had to see the humor in that. :devious
Opps, sorry man.. I guessed it was a bad copy&paste for a reply different than this one..
Different frequences, sorry I didn't get it :banghead
My reply was my humorous addition to the thread :)
Discussion Starter · #9 ·
Ahh righty, i now see what you mean ;)
How are you supposed to get the plastic plug things out of the centre tho as they are flush?
cadbury can you post some pics i am curious to see the part of which you speak?:)
push in the center of the little black thingys with a narrow tip screwdriver not to hard tho just gentle like and they drop right out
Discussion Starter · #12 ·
Doesn't that make them tighter?
I thought you had to somehow pull the centre pin towards you to loosen it?
Daz.
once you push the center pin in it will loosen the plastic rivet and you can pull it out with you finger nail. then push the center pin down so it hangs below the rivet head before you reinstall it. It will make sence once you do it
Discussion Starter · #14 ·
Sorted, thanks for that dude ;)
The new LED sidelight/parking bulb looks sweet :) :devious
