1 - 2 of 2 Posts
Hi there
Been a while since my last post, that's coz she's running well, hoooray!
Got some work to do and have the manual but just thought some of you guys might have some heads up.
So, i've changed pads and fluid but have a set of braided hoses to go on. I have a Sealey vacuum kit on the way for the line change. Anything i should be aware of when replacing lines other than making sure all the air is out of the lines before closing up?
Next, i have a new chain and sprockets to fit (going back to standard sizes 17/39). Any hints? What should i loosen before removing the chain?
R
Ta
Brian
loosen the rear axle and remove the front sprocket cover and front sprocket
1 - 2 of 2 Posts
