1 - 12 of 12 Posts
I have a 97 TLS that I've been sorting issues out on. Last major one left is to get it to idle at a appropriate rpm.
I don't believe this is a cable tension problem since there is some slack on them. Idle screw is backed all the way out. TPS is set and air screws set to 1.5 turns out. If I set the tb's to anything close to even, it'll idle up high (over 3000 rpm). If they're out of sync a bit, it'll idle down and be ok.
Ideas of what I should be looking for?
check that the fast idle cable/cam isn't holding the throttle plates open?
i've backed the screw out two revolutions. doesn't have any affect at all right now. It acted the same when the cable was just hanging loose at the bars anyways
Weird. Somehow too much air is getting into the engine, either because the throttle plates aren't closing as much as they should (this should be easy to verify) or because you have a major vacume leak.
good luck
Will ride for Food
Check the throttle body boots..
Checked the boots with some carb spray. No noticable changes in idle with it, so the boots seem to be ok.
Gonna keep fiddling with it I suppose
*jumps up and down*
i know what it is!!
at the throttle linkage on the rear throttle body there's a screw that acts as a stop. with the throttle closed there should be a measured clearence. i think it's 0.20mm but check the manual.
yours will have negative clearence and holding the blades open even with the idle adjustor cable, throttle cables and fast idle cable backed off
Discussion Starter · #8 ·
tornado said:
*jumps up and down*
i know what it is!!
I think that may have been part of it. I've backed it off earlier and have left it loose until I get all the adjustments made.
Part of the fun comes from the bike having been a bit of a project for the previous owner and it sitting for ~6 years before I put a day into reassembly and getting it running. Perhaps it wasn't such a great deal after all? :dowhat :laugh
Discussion Starter · #9 ·
I think I've gotten it at this point. The return fuel line from the FPR was run incorrectly and so it was getting way more gas than it needed. Gonna go ride it tonight some and confirm all is well
Discussion Starter · #10 ·
Other than a abrupt on/off throttle response, it seems to be working correctly. :bounce
Mine was to low and kept cutting out! Had a play this afternoon and think I cracked it top man phil. Right side of TB pissy little screw and nut!
Discussion Starter · #12 ·
Curred with correct tension on throttle cables. Gonna double check the chain tension too.
1 - 12 of 12 Posts
