Im going to wire in a hid kit for my headlights but I have to wire a ballest in for each bulb, can anyone suggest a way of connecting up the ballests so they are only live when the ignition is on, I was going to run a live from the battery but this means they would be powered all the time and I don't want them to drain my battery
A well made HID kit will still use the OEM headlight circuitry to be on or off per OEM requirements. In other words, the relay Six5 speaks of will be included in it and the HID kit will behave exactly the way the OEM headlight did.
I personally would advise against HID kits of other reasons.
Edit:
In addition to the ballasts the HID kit came with, there should be a box and a connecto to connect the kit to the OEM lamp.
Although HID's use less current once started, I think they take around 9amps to get them started. That's a big load for our wiring.
The 2 HID's I have fitted on my R (you didn't say R or S) came with a relay and a wire that goes directly to the battery to provide power. The bikes original harness is then only used to switch the new relay.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
TLZone Forums
A forum community dedicated to Suzuki TL sport bike owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, racing, troubleshooting, maintenance, and more! Open to all TL1000R (TLR), and TL1000S (TLS) owners.
