Anybody know the OD/ID/Free Length/Rate of a stock TLR ohlins rear spring ?
The OD is 85mm
the wire diameter if 13.5mm
the spring is 138installed to there is room for 150 free length from the look of it.
The OD is 85mm
Ohlins preload is 12mm so 150mm sounds right, just need the spring duty now :laugh
Checked mine last night and the spring code is 1093-89/210 L402
Which means
1093 = 150mm
89 = 210 N/mm, 21.4 Kg/mm, 1199 lbs/inch
210 = Nm
and from Stu the spring diameter is 85mm with a wire diameter of 13.5mm
