1 - 3 of 3 Posts
Has anyone had any trouble with oil in the airbox through the tappet cover breather hose? I have modified the airbox and i've put in a K&N racing airfilter.
I have solved the problem by putting an external breather on the tappet cover breather hose and blocked off the hole into the airbox.
Has anybody else had to do their own modifications or is there a better solution.
Large.
Some people build a breather system an air /oil separator . If you do a search you'll find it.
I just put a hose from the rear cilinder breather strait out and block the inlet hole on the airfilter box.... I didi it long time ago. Never had problems or oil in the filter since I did it...
1 - 3 of 3 Posts
