Help with Ducati/TL project coolant system.
678 Views 8 Replies 5 Participants Last post by  Sam
Does anyone have a diagram/info on the TLR coolant system?
I can find the parts list picture of the hoses but it does not tell me where the hoses go on the engine.
I’m trying to use the Ducati radiator but I don’t have any hoses for the TL engine yet so i need to know where they all go before i splash out on some.
Pages 5-1 & 5-2 in both manuals (TLR & TLS) give a decent view of where the hoses are used in the cooling systems.
my links have a ducati rad on a tl :)
and detail the hoses you need to fabricate
Show off! :laugh
Ring-in your links have help but I’m still not sure on how the water pipes are routed that come out of the oil filter housing?
Six5 is that the service manual you are talking about? I only have a Haynes manual that is as much use a chocolate fire guard.:confused
if its an R motor then T into each of the radiator hoses
the direction of flow in the heat exchanger doesn't matter
.....Six5 is that the service manual you are talking about? I only have a Haynes manual that is as much use a chocolate fire guard.:confused
Both OEM service manuals (TLS & TLR) can be downloaded from http://www.wotid.com.
Another chocolate fireguard :laugh
