1 - 2 of 2 Posts
After 5 months. my mechanic did what I think is a bad job with the swap. I have a TLS with a R motor in it. THe motor is supposedly fine. Today I was riding around under 50mph and it started cutting off as I let off the gas in 1st gear. It would start back up right a way but would do it again? it also is a little jerky in 1st too.. Fuel injection issues? Remap? When it is over 60mph for longer than 10 min it leaks a half a dixie cup of oil out of the top of the motor. Any ideas?? I'm really bumed out about it I missed the entire riding season and I'm broke:rant For something that is supposedly really easy he was complaining that it was a bitch to work out leading me to believe something was done WRONG..HELP
I'd start by checking that the TB's are seated in the boots and that the TPS is set properly. Then check that the crankcase breather system is as it should be then get it re-mapped.
Is it leaking oil out of the motor of the air box?
good luck
1 - 2 of 2 Posts
