1 - 10 of 10 Posts
Then you might not have got the wiring correct :O Go thru' the loom on the bench and double-check................. never had any prob's on mine :confused
where did you terminate your new harness?? the mod is pretty simple... got any pics? pics will help...
your new harness has to be connected to the harness coming from the rec/reg...the part of the harness still attached to the rec/reg...if you connected the wires to the other part of that harness that was unplugged from the rec/reg you will be running off battery alone which may cause some problems with your gauges...
toledo is that correct??
Sounds about right.............. what bike is it, an R or the superior S? :devious I don't know if there is any diff' in the make-up of the loom :O
the instructions will work for both...
another thing is check the harness on the left under the ram air tube cover...in particular check the yellow harness...if any of them are hot to the touch or have loose connections that could cause your problem as well...the connectors tend to corrode hence the charging mod...
cool...now go rider her and have some fun...
1 - 10 of 10 Posts
