'97 TLS cases apparently have a smaller flange for the oil filter, the TLR heat exchanger wont fit it.
The TLR heat exchanger can be fitted to the later TLS cases.
As for which is better, assuming you've enough cooling capacity to cool the oil with the water, the heat exchanger is better as the oil radiator doesn't do any good when stopped in traffic and likely over-cools in very cold weather.
