Hi everyone,
I am trying to remove the headlight, all four bolts have been removed and the headlight has been slid out. However it is still connected via the two wires going to the bulbs. There is a connector going into the headlight but I cannot seem to pull the connectors free from the headlight.
Am I doing something wrong? Any help would be very Grateful.
Many Thanks
David
Remove the rubber bulb covers and then disconnect the bulb connectors.
the connectors just pull of. wiggle them a little. The bulbs are held in with little wire clips. nothing else holds the headlamp on. Unless you have a side light bulb. This just pulls out from underneath.
