The Fork Swap Chart says the Busa front end should fit.
http://www.tlzone.net/forums/freque...tl-hayabusa-fork-swap-chart-measurements.html
However, these issues come to mind, as I'm not familiar with the Busa triples.
Otherwise, should be plug-n-play.
- Ignition switch mounting and steering lock location?
- The lugs on the lower triple for the left/right steering stops?
- The Busa forks are significantly shorter, so the geometry will change.
