1 - 20 of 20 Posts
time to put it together :banana
setting the table
little bit of lube
my wiev to the left
some milling adjustment of the chain guide
to keep it clear of the sprocket
here we go
new shims and lubed up
prepped for step 2 BB installation
Discussion Starter #2
rings on
tada
E-base gasket
gasket on
to prevent dropping the clip into the motor
cylinder on
some gasketglue
check the TDC and adjust the cams
thighten
Good job :hail
It's about time slacko. When did you destroy it? September? :bitchslap
It's about time you showed up here too. Del has been copping too much heat without you.
dang fulla - you're not shy with that lube are ya :devious and whats with the condom on ya hand :laugh
Nice to see ya back anyhow :bigfinger
Figures you would find hot pink lube, Lasse. :dowhat:lol
Good work, bet it'll pull really well now:banana
Is that power coming from the goddess Athena? :D
don't forget to dial those cams in :devious
Sweet stuff Lasse still running the Edelbrock? Or did you get a proper carb?
I remember the sweet cut I put in my finger holding the jug and piston up after I changed the base gasket.
W
Guest
whow, great work there lasse :thumbup
you are well trained in putting your head on the barrel :laugh :laugh
Discussion Starter #13
Yes Sir still running the Edelbrock havent got the $ for an fcr39 right now I will get it to a dyno and see how it runs rich or lean or maybe good :)
Discussion Starter #14
you know it girlfriend :devious
Discussion Starter #15 (Edited)
All shiny and pretty. Mmm...
Could not tell from the pics, but do you have a manual cam chain tensioner on there? If not, Thumpertalk sells one and APE makes one for the original Hayabusa that bolts right on too. I have the APE job on mine.
Discussion Starter #18
yep I have one on :)
nice p whoring lasse! :)
Discussion Starter #20
went for a ride today in the snow :roost it pulls like crazy no pics since the camera was left at home
1 - 20 of 20 Posts
