I have (yet to be tested ) a problem with 5 th gear jumping out of gear . Which i assume means the dogs on the gear are worn .Hence the cog has to be replaced .The dogs on 5 th mate into the 3rd and fourth cog (single unit ).
Is it mandatory to replace both gear or is it just possible only the dogs on 5th have worn ?
I mean ,where do you stop ,they are probably ALL worn .
the dogs either engage other dogs or recesses in the mating gear.
you have to inspect the shape of the point of engagement to determine if they are usable
most bits will be worn but they will be suited to the klms...no easy way apart from splitting....i have a few gears sitting around if it helps...no teeth busted....can do some kind of deal :devious
