Was replacing the gauge cluster bulbs awhile ago with LEDs.
I couldnt find out what type of normal bulbs to get, only found results for LEDs.
Turning the bulb mount wasnt as smooth as it was with regular bulbs.
So I used needle nose pliers on the one, slipped & scraped off a circuit on the back of the gauges... :banghead :banghead :banghead
Already have a donor gauge set otw from ebay to remove the circuit from that & solder it onto mine (donor gauges are broken)
Now have an error on the gauges & cant check it right now.
Anyone know what circuit (or whatever its called) does / controls?
its the one above the bulb mount in the pic.
I believe it says C102
Tried to find the thing when it first happened but had no luck.
