Can anyone tell me how much gas is left in the tank when the gas gauge light starts to flash, and when it goes solid? I don't have an owner's manual, and service manual doesn't cover that.
Thanks
Mine has just under a gallon when it starts flashing - manual says it should be ~1.2 gal IIRC. Seems if I fill up right after it starts flashing I put in ~3.7gal and if I run it till it won't run anymore then fill up I put in 4.6 gal.
TLR might be different though, esp if its a CA model.
+1...for the TLS...
Once the light starts flashing on my TL-R, I can put 3 gallons in it. I THINK they have a 4.5 gallon tank, so that gives you a gallon and a half once it starts flashing
I think my usual fill is 14 and a bit litres..I generally fill within 10-20 miles of little yellows first apearance and since my range per tank (from full till flashing)varies from 70-125 miles I am never that sure of how quick I am going to run out once its winking at me.She is too heavy to push far...
D
Guest
I'm pretty sure it's about a gal when it starts to flash and then half a gallon when it goes solid.
