That "choke" is no choke...It could be running rich. I let it warm up to about 120F befor I ride. I never use the choke, I just let it idle low untill it works itself out. there is no smoke that comes out when I start it, and it runs normal temp 180-200 F.
definatly not coolant. coolant level has been stable for awhile. not sure about water.Are you positive it's fuel? Maybe water/coolant leakin in through the head?
C
That is right on! there are leaks at the push rod seal and all over trans out. the breather goeas from the crankase to the upper left of the airbox right? there is lots of crap commin out of this area of the airbox too.Leaky injectors. Just look down the TBs aand watch for a drip.
Or could be a clogged breather or kinked breather hose causing lots of blowby. But usually you'd see other leaks like at the pushrod seal, trans output shaft, water pump...
