1 - 20 of 25 Posts
Make me an offer I cant refuse...prices dont include shipping...all pictures available! I just took them today!
http://s889.photobucket.com/albums/ac97/vtwinjunkie/
TL1000R 98 EVERYTHING MUST GO!!!
Thermostat housing $20
Fan (little bashed but works) $40
Cush drive W/ housing $40
Axle spacers $15
Rear brake assy. $60
Rear suspension stock complete $40
Misc. inner fairing plastics $25
Misc. hoses $10
White frame sliders $30
Stock pass. Pegs $40
Stock pass. Pegs painted black $30
Stock 39 tooth rear sprocket $25
Rear blinkers $15
OEM reflectors $3
Swing arm bolt $10
Battery box W/O lid $15
Lower radiator bracket $8
Rear brake light switch $15
(2) Kickstand switch $10
Front fender (cracked) $25
Inner V fairing $20
Main wiring harness $100
(2)Intake trumpets $15
Complete triple tree $75
(2)Engine mounting hardware $30
Black frame slider ½ and both brackets with bolts $20
Airbox sensors $20
(2)Shift linkage $15
Rotor bolts $8
Rear set bolts $8
Coils $40
Rear axle $20
Front axle $20
Brake light $15
Front cylinder assy Misc. springs, bolts, ect. $20
Front sprocket cover $15
RH control and throttle tube $50
LH control / hand grip $40
Gas tank bracket/ spacers/ bushings ect $30
RH side inner rear cylinder dress plastic (velcros to frame) Not broken or cracked! $15
Starter relay $15
Ram tubes $25 each
RH case cover $40
Clutch cover with clear clutch sight glass $40
LH magneto cover (slight damage to clutch area but works fine no leaks) $40
LH magneto cover with busted allen head but everything else fine small scratching $30
Magneto $50
Rubber intake boots $15
Starter $50
LH case $50
RH case $50
Rear cylinder $30
Rear cylinder head complete with valves $60
The crankcases need to stay together as a matched pair :thumbup
Banned
ILL TAKE THE HARNESS !!! Is the headlight harness included ?
Email me :
[email protected]
Discussion Starter · #18 ·
THIS IS UPDATED>>>>>
Axle spacers $15
Misc. hoses $10
Rear blinkers $15
OEM reflectors $3
Swing arm bolt $10
Inner V fairing $20
Airbox sensors $20
Rotor bolts $8
Rear set bolts $8
Coils $40
Rear axle $20
Front axle $20
Brake light $15
Front sprocket cover $15 (sold 1 and have 1 remaining)
Starter relay $15
Ram tubes $25 each
RH case cover $40
Magneto $50
Starter $50
LH case $50
RH case $50
Rear cylinder $30
interested in the frame sliders...how much cutting was involved? Ship to 80640...do you accept paypal?
Thanks,
Travis
1 - 20 of 25 Posts
