1 - 19 of 19 Posts
hi everyone
i want to give me injectors and fuel sysytem abit of a clean out can anyone recommend a good product that isnt going to cause any long term problems
I think ive had a bad tank of fuel so i want to clean it and a good clean out
i know there is alot of products out there but i want to use one that everybody else has used if you know what i mean
cheers everybody
cheers hammy but ive never heard of sea foam in the uk and i dont think ive seen it anywhere for sale either
cheers bud
ill give the stp fuel system cleaner a good try out and ill post up what happens so it give everyone else some idea
thank you hammy
Gas itself is a good cleanser. I would just take your tank off and run some gas through it and change your fuel filter..
give redex a try ive used it on a few of my bikes with good results however not done my tl yet, did give my sv650 a good improvement, whether that was just in my head but i swear it felt better, hope it helps :O
Discussion Starter · #8 ·
ooh redex im abit suspect of redex madmat after i saw what i did to my brothers car it might be different on bike but ill give stp a go
Id be interested to see what results people have. I put some redx in my car for the first time other day. Didn't seem to make much difference, but then again I haven't done mnay miles in it since. Thinking about putting 'something' in the TLS though
SeaFoam is a neat additive as it is not a true solvent. Most fuel additives have Tuolene or Xylene or SuperCorrosivelene. I prefer to use those only if I know I will use the fuel in a short time so it don't sit in the system any great length of time. If you use STP try to run it thru in short order.
SeaFoam is a combination of fine oils. It does have a similar effect as some solvents but not as harsh. I prefer not to use any additives in anything I own unless I think they work, which most don't. SeaFoam works to gently clean and loosen stuff without damage. It might have a different name outside of the US.
I always use Lucas fuel additive. Dont clean anything real fast..but over time you will notice a pickup in fuel economy which means it worked :p
How do you use the seafoam? Do you pour the whole bottle in the tank? Change the fuel filter before or after using seafoam?
Seafoam does work, well... the only stuff that i can feel does something
yamaha ringfree works great as well. I also 2nd the injector cleaning. I sent mine to witch hunter performance, had a nice printout of before/after flow rates, matchin, etc. Bike seemed to run smoother afterwards as well :thumbup
We got CRC or STP branded fuel system cleaner. I stick it in the TL cos it's cheap and it may or may not work :laugh but it hasn't done any harm. Used to notice a difference in the Pajero Mini. New fuel filter is a very good idea :yes
1 - 19 of 19 Posts
