Ok, I have found half of my answers regarding the fuel level sensors here ; http://www.tlzone.net/forums/help-forum/127900-aftermarket-koso-speedometer-setup.html
The fuel inj light I'm not sure about.
The starting problem, may have something to do with the battery or charging system, as the times it has had trouble starting ,I have then changed the battery off the bike, then it starts and runs fine. I tested the battery after charging, it reads 13.3V ignition off. When the bike is started it reads 14.4V. Next time it wont start, I will test the battery's voltage immediately. Maybe the battery isnt that good or there is some current leakage.
