1 - 2 of 2 Posts
I rebuilt the calipers and put on new steel braided lines a couple weeks ago. I used the double banjo bolt at the lever as opposed to the right caliper as the new lines were plenty long to do this. The problem is that I have bleed about a gallon of fluid through the system and still the lever will not firm up the way I think it should (engages about halfway through the lever stroke). I have a mighty vac and followed the instructions, but something is messed up...Any ideas? Thanks.
Follow The Ring-In's advice in post #8 in the thread linked below.
1 - 2 of 2 Posts
