1 - 10 of 10 Posts
Hi all
I'm looking for a front brake master cylinder for a set of TLR brakes. Thus TLR 5/8" (16mm) master cylinder or GSX-R 600/750 04+ or GSX-R 1k 05+ 3/4" (19mm) radial master cylinder.
Not really looking for aftermarket stuff. I want to use widely available levers.
T
Guest
16mm Brembo Radial M/C from a Yamaha R1 - 2004-2005 www.ronayers.com
Parts found with Part Number: 5VY-W2587-00-00
Description MASTER CYLINDER SUB
Price $64.52
Parts found with Part Number: 5VY-83922-00-00
Description LEVER 2
Price $28.33
Your brake switch and lever shaft will work.
Brand new and around $100.00, E-Bay used...even less...Scott
Actually not a bad idea, I just need someone that ships it to me (no overseas shipping from Ronayers).
Anyone ever tested that on a TLR or with 6 pot brakes?
A what?
If your talking about the assembly and resy I have one for sale or trade!
The AP is sweet:drool
But if you end up needing shipping from the states I'll foward whatever you want to you.
T
Guest
Yamaha and Kwak's are running radials on the 600's and 1000's. Nissin with Suzuki and Kawasaki and Brembo with the Yamahas... FYI 16mm is a little over 5/8th and works six pots quite well. 19mm(3/4") will require less lever effort but you may lose some"feel"...Scott
1 - 10 of 10 Posts
