1 - 10 of 10 Posts
hey guy's i was just trying to take off my front rim and tire and it seem that the front axle bolt is frozen on the axle so my question is does anyone have any ideas? :O
Loosen pinch bolts on nut side, should be torqued to 72 ft-lbs.
i did that, the bolt seems frozen to the axle
uh, the bolt is the axle. you sure you loosened the throttle side pinch bolts?
sorry the nut is frozen to the axle and i can't take it for a ride as it is partaily dismantled right now. i will try a pipe wrench tomorrow. anyone know what size wrench fits the axle nut?
are you 100% certain you're doing this right? tell us exactly what you've done so far. i'll lay it out if you're not 100%
the nut IS the axle.
you aren't doing it right..
stop
read
read again
remove wheel
ok i got it off. here's what i did i loosend the two pinch bolts on the throttle side,raised the front end and loosend the axle with a pipe wrench. it was wicked tight maybe the guy before me over tightend it. when i put it back together should i put some never sieze on the threads?:)
1 - 10 of 10 Posts
