This should help to sort through the numbers.
http://www.tlzone.net/forums/freque...tl-hayabusa-fork-swap-chart-measurements.html
If I get Troy's forks and put them in my current Attack TC (are all r/t forks the same diameter for upper/lower TC?) which Marchesini wheel and which axle should I use??I'm using TLS lower, VAN's upper triple, the forks are GSXR 1000 K5/K6 spec, so I'm using SAMs fitting kit (0,5mm sleeve) and BUSA spindle
Hi All,
I am hoping to by Troy's Ohlins forks (in the FS forum), and a replacement Marchesini wheel from Speedking. This is to replace my current, damaged, Ohlins r/t forks, which are in an Attack Racing billet TC. I need to make sure all this goes together, so I asked Troy about his current setup and he said:
Thanks,
P
The newer-spec Busa wheel ('08+) should have the correct spacing for the rotors, so the rotor spacers won't be needed if the Ohlins forks locates the caliper mountings the same as the Busa forks..... I will be getting a newer-spec Busa spindle.
Question: if I get a newer-spec Busa-compatible Marchesini to replace my trashed TLS-spec Marchesini, can I forgo spacers/adapters??
However, the caliper spacers may still be needed.
