Hi
Anybody know if fork oil seals are the same/interchangeable on both the TLR & S ???:O
I think all seals are the same if the right size. I called a Kawi dealer about re-springing my forks and he said he would use seals on hand to replace them.
I got some dust and oil seals (it's good to replace the two together) for my S from the Suzuki shop, and the ones they gave me were for a GSXR1100S<W:O. So It would seem they are interchangeable between models:)
They're different.
Oil seal
TLS = 51153-46E20 (TLS only)
TLR = 51153-02FA0 (TLR / Hayabusa)
:dowhat
Dust seal
TLS = 51173-46E20
TLR = 51173-02FA0
(Using 'where does this part fit' on ronayers for reference. The TLS units are unique).
Just found the packaging from the GSXR1100 dust seals, (can't find it for the oil seals) and the part no is 51173 46E20:O.
51153-46E20 is listed for the 1100 on ronayers, just doesn't come up in a reverse part look up. Only the TLS does :crazy
Hi
Thanks Steve was given S seals at dealers and told they was same as the R a quick check shows them to be same diameters but haven’t got the old ones out to check width . Will take them back come Monday sods law that sun is shining an bikes in bits
Paul
my bet is they may not be absolutely identical but will work just the same.
i got given the gsxr1100 ones by suzuki as well !! must be an nz thing.....
