Yikes. Surely that must have felt a bit weird to ride on? Then again, maybe you secretly want a single-sided item. :devious
and maybe fit some tabs for a centre shock conversion. You never know what the future holdsSam could weld that.........:devious
This mod is for the '97 with the recall 1-piece damper mount- unlike the later S's which are a 2-piece. To lift the tank you have to un-bolt the whole left-hand damper mount, including the stay inside the fairing, which is bolted to the radiator mount and the fairing stay mount, a right PITA if you don't remove the left side fairing. My mod drils a deeper hole on the left side where the damper bolts to the mount. This is then re-tapped.I then cut off the upright piece of the mount, which then stays bolted to the frame. Using a longer bolt for bolting the damper to mount means I have now emulated the later two-piece mount.TLJimmy what is your 'damper mount mod for easy tank lifting'??? Sounds good to me! I had drilled studs with pins & springs on my old TL, with a wire between the pins, so I just pulled the wire and lifted the tank. But that TLS had a long steering damper along the frame rail. Right now I don't have a damper on my TLS, but I will add a hyperpro as soon as I can afford one.
