I still cant download the TB Sync video tho :banghead :banghead :banghead
no tlr suspension specs?
What sort of specs do you need. Set front sag 35 mm, set rear to 30 mm, if you can and run the adjusters for best feel, usually all the way out on the stock damper, about 4 clicks on the fork adjusters. Does that help?
it won't let me watch the tps vid :banghead :rant
