1 - 3 of 3 Posts
Hi All,
Do any of you use an external fuel pump?
What one do you use?
Any idea of the spec I should be looking for?
Any info would be good to get me started.
Thank you
early Busa uses an external pump - if you can find the space for it, prob be able to find one 2nd hand cheap enough to try? why an external pump? did consider it myself once to try and stretch the tank range a bit but then decided wasnt enough to worry about, I also looked at different aftermarket pumps and even an adjustable pressure regulator, will see if I can find my old notes....
Thanks for the quick reply, just looking at my options at the mo, I am thinking of changing the clocks, then all sorts of mad ideas entered my head.
I would also need space for the filter as well and get the whole lot out...........
1 - 3 of 3 Posts
