1 - 3 of 3 Posts
I have my motor torn down to get to the tranny. I had a problem with fourth gear. Turned out to be a worn out gear. Now shes ready to go back together, but should I change anything else inside the case? Like the oil jets?? She has 76 thousand on her.
check the oil pump.
fit a set of rings
have the valves and seats refaced professionally
reshim the cam followers
check the cam chains for stretch and the tensioners for wear
What bike? - early S pumps are not as good as late/R ones. I'd replace for later type or re-use only if in very good condition, no scoring etc.
Piston rings
Check oil jets are clear but no need to replace.
I'd change the output shaft bearing, again, espcailly if an early S
Big end shells are cheap, I'd replace at that milage. 76k They've done their time! Mains seem to run on forever if look okay.
Check mating gear with forth/all gears very carefully, one rarely get worn on its own. Selector forks if signs of scuffing.
Stick some parrafin etc in the ports, see if leaking? Lap them in.
check the scissor gears are not badly worn (dissemble or pry apart and feel for tension)
check tensioner has no shiny marks on teeth?
1 - 3 of 3 Posts
