My wild guess is that the fuse blowing isn't directly because of the motor running, but rather vibration. From what I understand she'll stay on without the motor running.
Have you tried to move the wires around while it's in the ON position but motor out? I would try that to see if there is an area of the harness will make it blow.
More common areas of shorts have been near the steering column, so that's where I would start moving things around.
