Check the large gang connectors on the left side up near the headlight. Look for green corrosion and clean it up if present.
Fixed it for you, Angry. Since it is a TLS.....Check the large gang connectors on the RIGHT side up near the headlight. Look for green corrosion and clean it up if present.
Though the S was on the left and the R was on the right. Might have to reroute my wiring harness then.Fixed it for you, Angry. Since it is a TLS.....
Beppe, also check the starter relay connector. It is known for causing such symptoms. If the terminals are overheated or corroded, it is likely the problem. It is under the seat, behind the tank.
