I'm guessing if you are doing this, you have replacement studs to put in. So all you need do is measure those to determine the depth.
Make sure you are using split point drill bits, so that they don't wander and help you to drill straight. Centre punch the stud before drilling, small pilot drill a few mm first.
Good luck!
Good luck!
